Locktight on Rocker Arm Botls?
Old 05-09-2007, 08:16 AM
algws6's Avatar
Default Locktight on Rocker Arm Botls?
I was reading on ls1howto, and it sudgests putting locktight on the rocker arm bolts if your heads are ported and polished. Any truth to this?
Old 05-09-2007, 08:38 AM
slt200mph's Avatar
Yes it is true ..
Old 05-09-2007, 09:53 AM
Irocss85's Avatar
Originally Posted by slt200mph
Yes it is true ..
ah, not. you need to use thread sealer if the heads are ported and expose the intake rocker bolt hole inside the runner. otherwise you could end up injesting oil, or vac. leaks.
Old 05-09-2007, 11:15 AM
vettenuts's Avatar
Loctite will seal the threads. Just make sure you clean the bolts and the heads before using it or it will not help at all.
Old 05-09-2007, 11:53 AM
algws6's Avatar
and this is only if the rocker bolt breaks into the runner?
Old 05-09-2007, 05:11 PM
Viper's Avatar
Yes; no need to put it on the exhaust rocker bolts, just intake side. I used loctite thread sealer (looks green), or you can use permatex thread sealer.
Old 05-09-2007, 06:09 PM
LostCauseZ06's Avatar
loctite will NOT work on rocker bolts... trust me... ive gone through this problem 6 times now...
the only thing that works so far is indian head shellac compound.. its a thread sealer and worked perfectly on my engine.. i tried blue locktite, red locktite, RTV, mix of blue/rtv, mix of red/rtv.... hahah nothing worked except the shellac
Old 05-09-2007, 06:24 PM
Hardtop's Avatar
Loctite PST thread sealer works real well on rocker arm bolts. Used it on my Z/28, and it worked great.
Bruce
vettenuts's Avatar
The loctite sealed mine up fine, but the threads in both the head and the bolt must be perfectly clean. Second time use in the same threads, Permatex also recommends the use of another pretreatment on the threads.
Old 05-09-2007, 06:28 PM
i would agree with that. but the chances of getting all the oil out of the threads arent so great. the shellac compound was referred to me by a few very well known engine builders. you put it on both surfaces and let it dry, then put the bolt in and it bonds to itself and seals permanently.
with loctite it definately worked on some of the bolts... but certain cylinders were still getting oily when i took my manifold off. Manifold is now bone dry now that i used the shellac compound.
Old 05-09-2007, 06:57 PM
vettenuts's Avatar
Its funny you should mention this, my dad used it a lot and I have an old old bottle of it in my shop. Not sure too many people use it anymore. Also not too many people properly prepare the threads for loctite either for that matter.
Old 05-09-2007, 07:06 PM
haha very true napa carries the shellac btw. works super well and is pretty much dummy proof
Old 05-09-2007, 07:09 PM
1999ssls1's Avatar
Loctite has worked well for me.
Old 05-09-2007, 08:51 PM
Irocss85's Avatar
well I always use normal, paste pipe thread sealer. no tricks to it. spray bolts clean with parts cleaner, smear thread sealer on bolts, install. done.
Old 05-09-2007, 09:44 PM
NHRAFORMULA00's Avatar
ARP makes THREAD SEALER, for this application.Its in the ARP catalog.Use it on the intake bolts ,if the heads are ported.
Quick Reply: Locktight on Rocker Arm Botls?
