A/C Firewall Stuff, removal
Old 05-09-2007, 03:47 PM
trouse40's Avatar
Default A/C Firewall Stuff, removal
its a 94 lt1, any write ups? does it come out thru the engine bay or inside the car?
Old 05-09-2007, 04:11 PM
redneck01's Avatar
comes out through inside, but i loosened a lotta stuf and did it with my motor out. check lt1tech.com also try a search if you havent already
Old 05-09-2007, 04:49 PM
Fire67's Avatar
Supposed to come out through the inside... There's a writeup in here for 98+ cars, which is pretty much the same.
The BFH method works pretty well also...
OutlawZ's Avatar
you talking about the heater box????? if so have fun with it cuz it's a major PITA if you're not stripping everything out from behind the dash....
getting to the bolts is a pain but you gotta work on both sides of the firewall to get em...
Old 05-09-2007, 04:52 PM
the_merv's Avatar
I cut the front of it off and made a cover Panel, keeping the Heat.
I got rid if the little Vacumm Line goin in that is in the pic cause that whole thing stopped working. Heat works no problem.
This is what I got..
Old 05-09-2007, 06:33 PM
trouse40's Avatar
so i can do it like that and all the motors will still work fine? for heat and defrost?
Old 05-09-2007, 07:11 PM
the_merv's Avatar
Motors will work no problem, vents will work as long as you keep that little Black Vacumm Line. Mine all stopped workin, so I got rid of it.
Old 05-09-2007, 08:28 PM
trouse40's Avatar
so as lomg as i cut alone the firewall i wont cut anything i need?
Old 05-09-2007, 08:36 PM
the_merv's Avatar
Yup. You will have to cut a little out on the inside, where that metal piece is. If you leave it, you will block the air blowing from the Blower Motor. I am working on closing up all the gaps in there. Someone did it here also, they fiber glassed it all in.
Old 05-12-2007, 09:15 PM
NotACop97Z's Avatar
Fiberglass is messy and fun
Old 05-12-2007, 09:17 PM
NotACop97Z's Avatar
Old 05-12-2007, 10:59 PM
the_merv's Avatar
That's nice there..
Old 05-12-2007, 11:05 PM
Revelation Z28's Avatar
you have to take the dash apart to take the ac **** out???
to save myself time ill BFH the box
Old 05-13-2007, 12:30 AM
lethal93ta's Avatar
yes to do it the right way the dash has to come out, its a days worth of work to do it.
Old 05-13-2007, 12:36 AM
how do you unscrew the box assembly where the PCM is? or at all. on the firewall.
Old 05-13-2007, 12:38 AM
lethal93ta's Avatar
theres 10MM bolts that hold it fast to the firewall the bad part is some are on the inside and some are on the outside. if the engine is still in the car there hard to get to.
Old 05-13-2007, 12:46 AM
the ones on the side where the engine is i can get to, ive already tried.
the ones towards the PCM are on the inside?
Old 05-13-2007, 01:47 AM
hashtagBMW
Speed Density's Avatar
IMO you might as well delete all the HVAC if your going to remove the box in the engine bay. To much damn work with the engine in the car to do it nice and clean.
I just got done fiberglassing my heater box yesterday, got some bondo on it right now drying, will post pics soon.
Tony.
Old 05-13-2007, 01:54 AM
im just thinking of getting rid of the condensor, and the lines running to the firewall for the AC. make a little more room and let my lid breathe more.
Old 05-13-2007, 01:56 AM
hashtagBMW
That would be the only logical thing to do, remove the AC stuff itself but leave all of the box intact unless your doing the whole shabang of HVAC removal.
Tony.
Quick Reply: A/C Firewall Stuff, removal
