question about some headers
Old 05-10-2007, 01:37 AM
SchwabZ28's Avatar
Default question about some headers
I just wonna say Hi im new to the forum, But I was wondering a friend of mine just recently took his long tube headers off of his LS1, my question is, is there anyway you could make them work on an LT1. Thank you any info would help.
Old 05-10-2007, 02:07 AM
Bones Z28's Avatar
welcome
Nope sorry man. And the reason why is that the LS1 has round ports for their headers, our LT1 headers have what is called a "D" port, a D shaped port that bolts up. In a nutshell they will not match up so they will not work.
Old 05-10-2007, 02:46 AM
97Lt1TA's Avatar
pretty much nothing off a ls1 motor will work on a lt1 motor. two whole different motors
Old 05-10-2007, 02:58 AM
the_merv's Avatar
The LS1 Style Headers are spaced different, they are like a big block.
As far as the Ports go.. the LS1 Headers will work on D-ports, I have to use them for my L92 Heads.
Old 05-10-2007, 03:29 AM
Revelation Z28's Avatar
96capricemgr used round primaries on D ports before i think.
Old 05-10-2007, 03:42 AM
the_merv's Avatar
It really isn't going to make that much of a difference..shouldn't leak at all either.
Old 05-10-2007, 03:44 AM
do you use the round port gaskets or the D ports?
Old 05-10-2007, 03:47 AM
the_merv's Avatar
I am goin with the Round Ports, that will seal the Header better. I am using the Copper ones.
Old 05-11-2007, 02:25 AM
YellowB4Z's Avatar
Rule of thumb on an LT1. If the headers are D-port use D-port or round port gaskets. If the headers are square port NEVER use anything but square port gaskets or it will leat like hell.
Jeremy
Old 05-11-2007, 02:53 AM
Young_Z28_Racer's Avatar
i think its do-able... in tight budget ways yes... but in realistic and a good tight fit, no...
