Should I do it?
Should I do it?
One of my buddies has an LS1 pulled out of his 00 T/A its built with and LS6 intake, Fast 90/90, hooker LT's, Pacesetter ORY, and many other mods, he said hed sell it to me for 2500...also have a friend that has an A4 from a 99 Z28 that hed give to me, should I do it?
I assume you mean swap above into a LTx car. I say go for it if you are in need of a new motor. Also I think if it has the Fast 90/90, that means the fast 90 mm intake manifold with fast 90 mm throttle body (not cheap), therefore it does not have a LS6 intake.
Well does he have worked heads? You say built, does it have forged pistons and rods? If it's stock other than the intake system, I might take a second look at the $2500. If you can get the headers and the y pipe too, that makes it better but I don't know that I'd give $2500 for stock long block.
