Procharger Oil Leak
Old 05-10-2007, 09:14 AM
WHPLASH's Avatar
Default Procharger Oil Leak
Just changed the oil in the blower and there's a little buildup on the bottom now. That was without starting it up. Is that normal? I'm thinking it might go away, I hope, after running it and heating it up a few times. It wasn't leaking when I took it off.
Old 05-10-2007, 11:58 AM
AFASTYZFR1's Avatar
I have the same thing....small drop on bottom but never hits the floor...I just changed mine too and it is not coming from the drain plug so I am going to check the dipstick today
Old 05-11-2007, 04:45 AM
EPP
EPP's Avatar
I can almost guarantee that it is coming from the dipstick. Replacing the gasket under the dipstick normally takes care of the problem. There is a new gasket taped to the top of the white boxes that ProCharger packs the 3 extra bottles of oil in. Bob
Old 05-16-2007, 08:22 AM
ron williams's Avatar
Default procharger
i see you guys are running pro-chargers. how do you like them? i plan on having one put on my 94 HAWK...LT-1. i here alot about them good and bad. this will be done by thunder racing,also a 12 bolt will go in. it's auto with a racing built 60-e. the car is stock except for that and nitto 315-17 555R. i would like around 450 hp,that should be easy with a pro on it. am i looking at about 6000-7000.00 for this? ..........any input would be great...thanks..RON
Old 05-16-2007, 08:50 AM
AFASTYZFR1's Avatar
I love mine.....call Bob from exotic performance....he can help you out....his info is a post above yours
Old 05-16-2007, 09:18 AM
EPP
EPP's Avatar
Smile
http://www.exoticperformanceplus.com...tCar.php?car=7
Check out our '95 Formula with an ATI ProCharger P-1SC.
http://video.ls1tech.com/video/89b2f...a4011bec07.htm
Here is a video we puit together. Bob
Old 05-16-2007, 09:37 AM
E.A.'s Avatar
Consider that small leak "Sweat from all the Horsepower"
EA
Old 05-16-2007, 09:40 AM
WHPLASH's Avatar
EA
I hear you there. Funny
Old 05-16-2007, 11:15 AM
Ed Blown Vert's Avatar
I have that too. Seems to be normal.
Quick Reply: Procharger Oil Leak
