M6 pops out of 3rd?
Old 05-10-2007, 03:58 PM
nrmustang's Avatar
Default M6 pops out of 3rd?
When cruising and then decelerating in 3rd, I noticed my trans will pop out of gear (happened a couple of times today) I do have a B&M Ripper, but it did it with the stock stick too.
Has anybody had this problem? The car only has 19,700 miles (2000 SS)
Any help is appreciated
Old 05-11-2007, 09:35 AM
dantastic01SS's Avatar
I didn't have the problem with the stock shifter but now it happens all the time with the B&M "upgrade". I'm putting the stock hurst shifter back in.
Old 05-11-2007, 11:31 AM
nrmustang's Avatar
Do you think it could be anything else, like a bad trans mount making it vibrate out?
Old 05-11-2007, 11:44 AM
warp10's Avatar
Could also be a bent 3-4 shift fork or 3-4 synchro assembly problem.
Old 05-11-2007, 12:45 PM
nrmustang's Avatar
Would there be any other symptoms to a fork or synchro problem?
The car shifts just fine and has no other problems.
Old 05-11-2007, 01:36 PM
warp10's Avatar
Mine was poping out of third and poping out of reverse.
Replaced the 3-4 shift fork to steel - Fixed the 3rd poping out.
Replaced hats on reverse (They were all busted) - Fixed the poping out of reverse.
Old 05-11-2007, 10:04 PM
SShawn's Avatar
mine popped out of third as well, i rebuilt it and got a steel fork and new 3-4 slider, doesnt pop out any more. the only way your shifter is the fault is if you somehow messed up your install and the rubber boot is interfering you from engaging 3rd fully (this is very unlikely) this sounds like an internal problem all the way
Old 05-12-2007, 12:35 AM
Mike44138's Avatar
If the shifter has adjustable stops check to make sure they're set properly.
Old 05-12-2007, 01:02 AM
nrmustang's Avatar
The shifter install was pretty straight forward, no problems, didn't do shift stops either(not first shifter install)
Sounds like as you all have described- an internal problem. The car only has 19,700 miles on it and was bone stock when I bought it which makes it all the more weird.
But I'm not the original owner so who knows if the last guy ape shifted. Did you guys just take yours in to the local trans shop to have them rebuilt?
Old 05-12-2007, 01:07 AM
Mike44138's Avatar
If it's doing it with the stock shifter and the B&M I'd bet it's the 3/4 fork. DON'T just take it to a local shop and tell them to rebuild it. You'll end up with some monsterous bill for a $50 part. I took mine to a dealer for the same problem (2000 TA) and they replaced the 3rd gear synchro, 3rd gear, countershaft, and 3/4 fork. Fortunately they were paying for it so I didn't mind, but if I had to pay that bill I wouldn't have been happy. To top that all off they installed the wrong input shaft in my trans after the work and I ended up pulling the trans 4 times before I figured out what they did. Either find a shop in your area that knows T-56s or turn to one of the sponors like t56rebuilds.com.
Old 05-12-2007, 02:04 AM
TwistedSS's Avatar
Sounds like a bent shift fork
Quick Reply: M6 pops out of 3rd?
