Oil Pressure ?
Oil Pressure ?
You guys with Cams or anyone for that matter what is your Oil pressure at idle? When crusing say in sixth with 17-1900 rpm?
I have noticed when the white turd is hot. The pressure will twitch between 37 and 40 psi, when crusing it is between 43-50 PSI. At WOT it dosen't go over about 64 PSI.
I was just wondering. I am running Amsoil 10W30.
In the summer time with an outside of over 100 degrees Fahrenheit mine, after warm-up at idle will go down real real low.At idle I've seen mine get around 30.
Thanks man, I am just a car hypcondriact
Originally Posted by Rokko
Mine idles at 40 hot, never goes below 40. Ramps up to 70ish at wot. I've got mobil one 0/40 in it right now.
Originally Posted by 01T-TopToy
I would like to ask a similar question, I run Royal Purple 5w30 and at idle, hot and warm temp outside I see mine at 34-38 psi... Is that acceptable or should I go to M1 / Amsoil ?
teh PuRpL3z
