Brake Bleeeding??
Copy & Paste Moderator
Originally Posted by 02BEAST
Hey guys I want to do new rotors and pads what size rotors can I go with I have 18" wheels I think factory rotors are 12" and also when I do rotors and pads do I need to bleed the brakes?
You don't need to bleed the brakes but its worth doing after a rotor and pad change so you can really feel the difference.
Originally Posted by z28bryan
I believe you need to use stock size rotors, which are sufficient enough for even track use with a good rotor. Unless you went with a different bigger brake kit like a C5, C6 or other kit.
