strano sway bar ?
strano sway bar ?
how is the stranoparts 35mm front and 22mm rear sway bar kit...performance, craftsmanship, reliability, value etc...
and how exactly would i go about mounting a 22mm sway bar to a moser 12 bolt axle tube...all the kits i can find are for 21mm bars????
LS1TECH Sponsor
Thanks coolformula.
The bars are Black Powdercoated. The endlinks and bushings are all new (bushings are urethane, links are upgraded to a larger size for more strength). The only issue we ever have is with the front u-bracket. The stamping die is wearing out, and sometimes the hole is not quite large enough for the bolt to pass. But 5 seconds with a file cures that (and yes, I'm aware of this and trying to get Addco to address it).
As for mounting. My bar wil mount anywhere a GM bar will. The rear bar also comes with new bushings. So if your 12-bolt will accept the GM bar it will accept mine. If you need some other hardware to mount a GM bar, just get is and use my mount bushings and U-brackets instead of the ones included in the kit (or just get the new relocation mounts if that's what you need. However--and I don't claim to know tons about 12-bolts, I believe it might only be the 9" rears that need such a kit. I personally just made sure the bars fit like stock, figuring that covers the most bases.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
sure thing...
__________________
