Cool weiand lingenfelter Manifold on Ebay
Hi Guys I was surfing EBAY and came across this cool looking Manifold it's a Polished Weiand Lingenfelter maifold do you think this would work on my 98 Trans Am? Do you think I should bid on it?
http://cgi.ebay.com/ebaymotors/LS1-L...10212934QQrdZ1
ive had that manifold before, and i actually liked it. It was a bitch puttin it on becuase its aluminum and it didnt seal right, so i took it off and used a sh*t load of RTV and that thing just sealed up pretty good. It uses your egr/air equipment,so thats good to go for your 98. And to tell you the truth, i actually felt a big difference in power. I actually liked it, everybody talks about heat soak, but those are just the people who never owned it and they are just thinking logically that it should have heat soak, due to it being metal...but trust me, its nothing. I barely notice the heat soak if any, its not that bad. So if you want too, and its a good price, get it. You can usualy get one on this board for bout 250.00.
I just got one from the for-sale foums here on LS1Tech. I haven't installed it yet because I'm gonna port match it to my stage 2 heads and 80mm TB. The access door on the bottom makes it easy to have gutted out for more flow.
that weiland is junk.....the opening for the manifold is to small.....Hotrod or Carcraft did a ls1 intake manifold shootout......most HP to least was Fast,ls6,6.0l truck intake,ls1, junk weiland was last
Since I recently picked one up, I will do a little home massaging to see how much power I get. If I feel its a little low on power for the mods, then I will swap on an LS6 intake and see how much more I make.
I'll never truly believe a car mag due to money from advertisments.
WOW, that Ebay link shows it sold for over $500!
