Hard to shfit
Hard to shfit
i have a 2004 GTO 36K.
clutch is has about 1k on it.
i took her on her firt trip to the track sence the new setup and it was shifting fine until i slipped the clutch out of the hole and it sliped through 3rd gear.
now its hard to get into 2-3-and 4th gear, i dont know about 5-6th.
no its only hard to shift when in into it hard... the clutch still is holding great not slipping or anything. and i changed the slave today because the pedal also started to feel weird when it happened. now the pedal feels ok, but it still will not shift at WOT... and also the pedal sticks now at WOT....
is theis the master, or is in in the trans, or is it the pressure plate...its not grinding, it just seame like im locked out of the gears...
