Conversions & Hybrids - Need Help!
sdimess84
05-12-2007, 12:48 PM
I got my harness from Current Performance yesterday. On the back of the motor I am having oil pressure sending unit problems. Here is what I have.
http://i24.photobucket.com/albums/c14/emarschang/sensoronmotorunknownwire.jpg
It is a 2003 5.3L. Does anyone know what that one wire plug goes to? I thought it go to the oil pressure unit, but it does not fit. I need some help please!
67rsss
05-12-2007, 12:51 PM
That is for oil pressure sender. You may need to change to an F-Body sender. My plug looks just like that one, and pops right on.
sdimess84
05-12-2007, 12:55 PM
any part numbers for the sender
sdimess84
05-12-2007, 05:43 PM
What year F body? I noticed that there are two available.
LS1MCSS
05-12-2007, 07:03 PM
I have one for a 2000 f-body if you need it.
01WS6/tamu
05-13-2007, 09:21 PM
Any gm sender will work. Just order one for a 2000 fbody or truck. That is the oil pressure sending unit wire. The newer trucks use a different style sensor than they used to use.
busta9876
05-13-2007, 09:39 PM
Is the sender in the picture the standard triangle shape like the TPS sensor? if so, just re-wire the plug and save from buying a new sender.
sdimess84
05-14-2007, 08:26 AM
I was just told from the guy that made my harness, told me used the one off my v6 now, or I have one from a 92 s10 4.3 that I can use.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
