Ls1 twin turbo
Old 05-12-2007, 04:04 PM
gonzospeed's Avatar
Default Ls1 twin turbo
Hi guys !
To first, sorry for my bad English.
I am new here and on LS1 engine area.
I HOPE YOU CAN HELP ME !!!
I want to build a twin turbo LS1 and fit it in my car (Ford Sierra Cosworth).First I wanted build a Mustang Cobra 4,6 engine, but engine gives me no space for the turbos under the hood and I want have the turbos like the LS1 GEN-Turbo kit, turbos on left and right side .
My knowledge about LS1 is not so good,because my decision for LS1 engine is new and need some help.
For the first time (building in next winter)I want go with stock engine and 7psi boost is possible that I had read here.
A year later want go with forged crank, forged H-beam rods, forged pistons, all studs, MLS gaskets and want go to 750rwhp.
So my question is !
Can I tune the turbo engine with the stock pcm or must I go to a stand alone like MOTEC or AUTRONIC?
From where can I get the software for the stock pcm?
It is all for the first.
Please let me know
Best Regards at all
gonzospeed
Old 05-12-2007, 04:08 PM
Tainted's Avatar
the stock pcm can do your first few things without a problem with good tuning. its gonna take a lot for you to need a stand alone system.
Old 05-12-2007, 04:15 PM
Grimes's Avatar
A lot of people use HPtuners to edit the stock computer. http://hptuners.com/
Post in the "forced induction section" of ls1tech, more help there. Good luck!
Old 05-12-2007, 04:32 PM
gonzospeed's Avatar
Thanks for the quick answere.
It looks so that the 7psi can be made with stock pcm and stock engine, how much power is it ca.?
What is with the stock software?
On eBay I saw Hyper Power Programmer, is it the same think like HP-tuner?
Best Regards at all
gonzospeed
Old 05-12-2007, 05:24 PM
Cam72aro's Avatar
Best Regards at all
gonzospeed
What country are you in, Australia? I was just wondering, along with the availibility or parts/ engines. Josh
Old 05-12-2007, 05:33 PM
Boo"SS"t's Avatar
You are probably thinking of HYPERTECH PROGRAMMER from e-bay, which is NOT what you want and certainly NOT the same as HP TUNERS which is also happen to be a sponsor here, look them up in the sponsors list.
Old 05-13-2007, 01:31 AM
gonzospeed's Avatar
I am from Europe (I am living in Germany but come from Bosnia-Herzegowina).
I will buy a complete LS1 dropout with t56 from USA.
Where is the sponsors list?
Must be changed the camshaft,valve springs, pushrods, roller rocker arm kit for the 750rwhp? What would you say to change for this power?
Who has turbo manifolds only to sell?
I will send pics from my project.
Please help me
Best Regards
gonzospeed
Old 05-13-2007, 01:57 AM
calongo_SS's Avatar
Here ya go:
For 750 rwhp you're going to need:
built trans
built rear end
built short block
fuel system
heads, cam, valvesprings
gauges
stock rockers will be fine, that's about it though
Old 05-13-2007, 09:59 AM
Cam72aro's Avatar
Please help me
Best Regards
gonzospeed
Awesome man, I love to see ls1 interests oversees, it is cool. Good luck with your build and if you need any help from us over here feel free to ask. Josh
Old 05-13-2007, 11:01 AM
gonzospeed's Avatar
Thanks alot guys for your help !!!
What is to do on the t56 to hold 750rwhp, is it not strong enough ?
Short block and fuel system I know what I must make.
Which head components must be fitted (springs, pushrods, camshaft) ?
Must I fit bigger valves ?
AGAIN many thanks for the help, am relley happy about your help !!!
Best Regards
Mario
It will looks like this
Old 05-13-2007, 11:25 AM
ocdwill's Avatar
Best Regards at all
gonzospeed
stock computer...
Old 05-13-2007, 05:52 PM
gonzospeed's Avatar
Originally Posted by ocdwill
stock computer...
is it realley so, or is it a joke?
How much RWHP are possible with pump gas US 93octane europe,Australia 98octane with LS1 engine????
gonzospeed
Old 02-24-2008, 05:32 PM
gonzospeed's Avatar
Hi guys,
it is so far, I am looking to buy a LS1 swap for boosting.
I have wrote here that the LS1 alu-block is good for only 750hp and must go to 6,0 cast iron block if want go higher.
Is it so right???
What is the different between the 6,0 and 5,3 cast iron block?
BEst REgards
Mario
Old 02-25-2008, 01:49 AM
chuntington101's Avatar
Hi guys !
So my question is !
Please let me know
Best Regards at all
gonzospeed
alright mate! are you from england by any chance?? nice conversion mate something i have thought about doing for a long time!
right to start off i think its going to be a tight fit for the LS1 under the Cossy engine bay. soo turbos up front might be tricky! another solution is to put either a single turbo at the rear or twins. works very well with the big CC of the LS engines. google STS turbos and see what you come up with.
as for ECUs, Emeraled (SP?) should beable to run the LS under boost no problems. dave walker in the UK has done some mapping for both a Esscort Cossy and a Rx7 with LS1's in there. also he is on the developemnt/testing team i think so knows the units inside out. also i think Motec is coming out with a LS specific ECU soon.
one thing you are going to have to think about is the gearbox mate! the little T5 wont take the torque the LS (esp with a turbo) can throw at it! i know some guys have fitted Skyline boxes onto the YB but it would problabe be easier to go with a T56 as they already bolt straight on. you might want to look for a ford 9inch rear diff aswell as i have heard the normal ones blow if you run big power!
PM me mate and i can put you onto some guys in the UK that will beable to help you out furthe.
Cheers Chris.
Old 02-25-2008, 02:03 AM
jkwalkercchs's Avatar
hey if u need lsx parts i got a guy in sweden that i ship bikes for i could talk him into putting it in a shipping container
what part of germany i have a friend in hamm,nrw
Old 02-25-2008, 06:06 PM
gonzospeed's Avatar
Hi Chris,
Thanks for help.
I am living in Germany.I have decied to fit the LS1 after I have bought a 4,6 SOHC Mustang engine and have saw the space under the hood is not enough and have measured the Chevy 5,7 LT1 engine and I think it is eoungh space for RS500 twins.
What is Emeraled???
I want try to race with the 2WD rear end anf if this will not hold I will go to Supra MK4 rear end or Ford Mercur 8.8.Yes I will go with T56.
@ jkwalkercchs:
I am looking for a complete LS1 engine and T56 swap.That is the first I need.
Later I need the forged parts crank,rods,pistons,double v. springs.
Let me know if you have somethink for a good price.
I am from Hannover,Niedersachsen.
Please let me know,if anyone knows how much HP can hold the LS1 Aluminium block, it is really important!!!!!!!!!!!!!!!!!!!!!
Cheers,
Mario
Old 02-25-2008, 06:12 PM
Tainted's Avatar
similar dimensions for LT1 and LS1 but just know that the 2 engines are very different
Old 02-25-2008, 06:13 PM
gonzospeed's Avatar
Yes I know,it was only for dimensions.
Old 02-26-2008, 01:14 AM
Please let me know,if anyone knows how much HP can hold the LS1 Aluminium block, it is really important!!!!!!!!!!!!!!!!!!!!!>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>..
u shouldnt have any problems out of a ls1 bloch horsepower wise
Old 02-26-2008, 01:34 AM
Hi Chris,
Thanks for help.
What is Emeraled???
@ jkwalkercchs:
Cheers,
Mario
WOW thats great new that the engine will fit! and with twin turbos to!
id keep an eye out for a Manaro in the UK or Europe for the engine and box. this is the only officel sorce of the LS1 that i can think of.
you could try having a word with stevieturbo on here. he put a LS1 and a vortec YSI into his old ford granarda.
dont worry about the ally block, it will hold more power than you will need.
Chris.
Quick Reply: Ls1 twin turbo
