need help
need help
I need help finding out where to run my remote wire to my amp heres the catch Im running all stock system other than the sub and amp and need a place near the rear of the car to get a remote wire hooked up? Can I run of the factory amp to get aremote wire? and where if I can?
Ungrounded Moderator
Unfortunately, there isn't a convenient wire at the back of a Camaro to use as a remote turn-on. Firebirds have the power antenna wire but Camaros don't. There is no turn-on wire at the factory amp because it doesn't use a turn-on wire like most aftermarket amps - it turns on when it detects audio signal from the head unit.
The Camaro head unit has the pin for a power antenna wire, it just doesn't have the wire in the harness. You can add it yourself but you'll have to run the wire from the back of the head unit.
Another option is a low voltage turn-on device. It acts like an electronic relay that turns on when it detects signal on a speaker wire. You could hook it up at the factory amp. A motorcycle accessory company called the Electrical Connection sells them for about $15 (they're not a sponsor obviously but you can google the name).
Well I think I may try to run it from the back of the head unit. Can you tell me where it is on the back of the head unit? Which Wire? Maybe a Diagram or something
Thanks for all the help WhiteBird00
yea im still using the factory head unit. All that im trying to do is get more bass and right now I have it wired up to 12v through the factory fuse block and using a rocker switch to turn it on and off right now, but im still wanting it to be through the ignition or something that has voltage only when the key is on.
ok I just got done looking through the FAQ and had never seen the diagrams before untill now, but I was doing some reading and found this.
9 - YELLOW - ignition controlled power
Could I splice into that to get a remote wire for my amp?
Thanks, Joe
Thanks, Joe
Thanks, Joe
Thanks, Joe
