sts kit
Old 05-13-2007, 09:53 PM
snaketamer's Avatar
Default sts kit
how would a stock lt1 hold up to an sts base kit as long as i keep the boost low????
Old 05-13-2007, 10:08 PM
JAvenger007's Avatar
just fine. get a tune even for 5psi. Also get an IC and you can run 5-7psi just fine.
Old 05-13-2007, 10:23 PM
camarokid94's Avatar
just do it if it blows build a low CR motor and turn up the boost hell ill help ya..... just write me a check LOL
Old 05-13-2007, 11:38 PM
snaketamer's Avatar
what do you think the car would run with stock with the sts a stalled th350 and a brake behind it, and 3.73's out back?
Old 05-13-2007, 11:49 PM
run as in 1/4 mile? Depends on alot of variables.
Ditch 3.73s if you can. Get a 2 step, and get at least a T67 or bigger.
Old 05-14-2007, 12:06 AM
snaketamer's Avatar
why do you say ditch the 3.73's?? what would everyone suggest? the two step will come when the new tranny goes in as well.
Old 05-14-2007, 02:23 AM
99Z28LS1's Avatar
turbos dont necessarily like high gears. they like load, the longer the gear..... the more boost you can have
Old 05-14-2007, 11:58 PM
jeffboy757's Avatar
i remember when i put 3.73s on with my big block. first gear became useless...
Old 05-15-2007, 12:53 AM
99Z28LS1's Avatar
i WOULD NOT put 3.73's on a turbo car, the lower the better. but you dont necessarily have to do 2.75's. IMO, 3.73's are more of an N/A gear
Old 05-15-2007, 06:04 AM
koolaid_kid's Avatar
3.42 is considered the best 1/4 mile gear for a 4L60e.
Old 05-15-2007, 09:00 AM
SSnakekiller's Avatar
We ran our original prototype LT1 STS kit back in 03 for a year and a half on 5psi and 7psi (with meth) before we finally decided to just forge it to go bigger boost. We now have it at 15psi.
If you get a good tune, you'll be all set for a long long time.
