View Poll Results: what speaker should i buy all are 6.5 inch bass drivers
JL Audio
20
46.51%
Elemental Designs
21
48.84%
kicker
2
4.65%
Voters: 43. You may not vote on this poll
upgradeing sail panel speakers
looking to upgrade my sail panel speakers and here are the the speakers i have found and want some info on them if you have and what speaker is the best sounding speaker compaired to the stock ones.
CDT M6 is another consideration - probably one of the better/best? as far as SVC.
TA though.....you're going to want the eD eu700s without any doubt, IMO since they are the only quality DVC replacement I know of that works best for Pontiac versions of the Monsoon system.
Originally Posted by JR HAWK 9
I have only used the 7Kv.2 and the CDT Audio M6 so that's all I will compare, but the M6 DESTROYED the 7Kv.2 in terms of midbass and total output in -my- setup.
Originally Posted by WhiteBird00
I'll second that. If you're keeping the Monsoon amp in a Firebird, the EU700 (now called the 7Kv.2) wires in just like stock, only requires a little spacer work to compensate for the greater mounting depth, and sounds much better than stock.
Ungrounded Moderator
Here is a thread about installing the ED subs. It is based on Camaro so your Firebird wiring will be a little different (4 wires, 4 terminals instead of combining the connections).
https://ls1tech.com/forums/wiring-stereo-electronics/639901-install-guide-w-pics-upgrading-factory-monsoon-subs-6-5-ones-ed-eu700s.html
There have been numerous threads about the HU lights. A little searching should turn up plenty of information about replacing with LEDs, etc.
I know a guy who is selling a set of JL audio 6W0's if anybody is interested...
You will need a spacer for the mounting depth just like the ED ones though.
do these need washers to make them fit or is it a direct drop in. do the speakers holes line up with the cars or would i be drilling new ones to make teh bazookas work. these are sum of teh first DVC speakers i have found actually
From what I've been learning, these need a spacer and the holes don't line up, but otherwise the wiring is just like factory. That's the most important part. Someone please correct me if I'm wrong.
