New LS1 Owners - Newbie Tech - oil pressure
fuseone
05-14-2007, 10:53 PM
hi normaly my oil pressure is around 40 psi but now its in like 35 psi would it be because the weather is getting hotter out now
Z28LS1camaroguy
05-14-2007, 11:58 PM
yes the hotter it is the thinner the oil will get, and creating less pressure.
staringback05
05-15-2007, 12:35 AM
that pressure is fine....
RPM WS6
05-15-2007, 07:14 AM
Yes it would. :nod:
xterminator
05-15-2007, 11:22 AM
mine is at 40 at idle its closer to 60 at wot
Intense
05-15-2007, 03:12 PM
Check some other oil pressure threads to see what other peoples are at.
I know there is a few.
98Camarod
05-16-2007, 12:05 PM
Mine used to be lower, but then I broke my oil pressure sending unit and it went up when I replaced it :jest:
It was 60 cold, 30 warm, and 40 at cruise.
Now its 70 cold, 40 warm, and 50 at cruise.
Who needs a new oil pump, just put a new sending unit :jest:
5_02ls1
05-16-2007, 06:17 PM
"Who needs a new oil pump, just put a new sending unit "
any 98 ls1 owner
98Camarod
05-16-2007, 09:14 PM
I know, when I do my cam swamp I'll put in a ported and shimmed ls6 oil pump. I just thought it was funny that it was off by that much.
RPM WS6
05-16-2007, 09:22 PM
any 98 ls1 owner
FYI.
All '98-'00 use the same oil pump. It is not '98 specific.
IMO, there is no reason to replace the pump in a '98-00 engine unless you're already in there doing a cam swap or you have some serious low oil pressure issues. Just being a '98-'00 engine alone doesn't warrant a pump swap. Tons of '98-'00 cars have 80-150k miles on the stock pump without issue.
staringback05
05-16-2007, 10:05 PM
any 98 ls1 owner
huh?? this statement hurts....dady make it stop
JohnnyC
05-17-2007, 12:06 AM
You will be fine with that pressure. Never hurts to ask tho...
woswill
05-17-2007, 12:35 AM
Mine fluctuates between 30-40
letsrun97z
05-18-2007, 11:15 PM
mine sits at a hair above red when its at 210d and about 10 at 180 @ idle is that bad??
RPM WS6
05-18-2007, 11:52 PM
Uh, yeah that's bad. 10psi at idle is not good. Make sure that the sending unit isn't telling lies first though.
letsrun97z
05-19-2007, 04:42 PM
its is an lt1 everyone say's that they sit lower then the ls1 it goes right up to 50 a wot just sits real low when hot just put m1 5-30 in it yesterday im going to do another oil change in a lil bit not sure what i want to go with 108k on motor
