Textralia 0Z700 engagement before/after break in
Old 05-16-2007, 07:54 AM
ConfusedGarage's Avatar
Default Textralia 0Z700 engagement before/after break in
For those using this clutch, did yours grab like one inch off the floor initially? Is this normal? I imagine as the disc wears the high spots down the engagement point should move back up, but it seems a little low.
Any thoughts?
Old 05-16-2007, 12:00 PM
vettenuts's Avatar
Bleed it some more, how did you bleed it?
Old 05-16-2007, 12:05 PM
I have it at someones house and they are doing it for me since I am short on time. I am not sure, and he is going to try bleeding it again to see if that helps, which I think it will. Thanks.
Old 05-16-2007, 03:38 PM
dixonk's Avatar
Mine grabbed identical to the stock clutch
Old 05-16-2007, 04:12 PM
02NBMWS6's Avatar
Mine enagaged and disengaged perfectly at first, but after 8k miles or so it stopped disengaging completely and that only led to problems..
Old 05-17-2007, 01:23 PM
LS1TECH Sponsor
Textralia's Avatar
Clutch engagement should be very similar to the stock pedal feel. The two issues I most often see with poor pedal engagment is air in the hydraulics, or a pressure plate bolt that has backed out.
If you continue to have issues PLEASE contact us @ admin@textralia.com.au with a number to get back to you at.
Let me be clear to anyone else. If anyone using our product has any sort of issue, we're here to help you guys with any tech support issues you have. Please get in touch with us.
Old 05-17-2007, 02:13 PM
Ok thanks, I will drive a bit and see what is going on with it.
Old 05-17-2007, 03:13 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Matt,
Are you sure you got a clutch for left hand drive? Theres your problem.
Bleed it more.
Textralia,
Is anybody using slave cylinder spacers with this kit?
Quick Reply: Textralia 0Z700 engagement before/after break in
