My rear right wheel seems to be tucked in more than the left?
not sure if the pics show too well but my right tire is tucked in more than the left. i'm scared this is a sign of a bent frame? what else could be causing that?
That is exactly what the adjustable panhard bar is made to correct. It is well known that almost every fbody has this issue (mine does too) and the panhard bar moves the differential left or right, as needed, by making the bar longer or shorter. BTW, my car is not lowered, has stock wheels and tire configuration, but is still shifted by 13/16". Just sloppy engineering by GM.
Make yourself a plumb bob.....get a couple pieces of string or fishing line & tie a nut or something onto the end of it. Tape the other end to the outer fender in the center, then measure the distance between the string and the center of the wheel. Adjust the phb until the measurement is the same on both sides.
Wow and i thought i was the only Fbody with that problem. Everytime i wash my car or just look at it from the rear, i would think some was off and it was that reason. I have seen it like that since i bought the car 3 years ago. Car works fine, but its bothers me to see things off like that.
-Joel
-Joel
Originally Posted by Spink
I was told by an engineer that almost all cars are purposely engineered like that. He explaind how it makes the car absorb bumps better but I don't remember exactly what he said but it made sense at the tme.
On my car, I believe it is the reason why my car slides to the right when I nail it from a dig. The adjustable PRB is the first suspension mod I am going to make on my car.
The engineer I talked too only worked in the automotive industry for a short time. He was at a car show looking at my GN and I mentioned I thought my rear end was off a little and that's when he told me it's suppossed to be like that. Take a look at other cars. Almost every car on the road you can see the same thing if you really look closely.
I have a hotchkis drop in the back with hotchkis lower control arms, and hotchkis panhard rod, 315's and really need an adjustable one, do i need relocated brackets, not sure if i have them or not?
