Do i need to worry about MAP sensor?
Old 05-16-2007, 07:23 PM
LS1Tech Sponsor
Superman09's Avatar
Default Do i need to worry about MAP sensor?
Ok hers the deal. Sent my intake out to Stryker last season to get painted with true fire. The clip that holds the MAP sensor down got broken off. I ran the car all last season and multiple track days in stock trim and it was all fine. However now with boost i am a bit worried since there is no securing clip. Think it will be fine just plugged in there or should i definitely seak action to secure it/replace the intake? Thanks!
-Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 05-16-2007, 08:09 PM
kp
kp's Avatar
My intake has had a broken MAP clip forever, I just used a few wire ties to hold the MAP in. Even though I dont use the stock sensor anymore its still stuck in there and has held 20psi. I wouldnt just leave it.
Old 05-16-2007, 10:12 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
damn jon still trying to get your car straight?
Old 05-17-2007, 05:22 AM
LS1Tech Sponsor
Superman09's Avatar
yea yea... This FI is some tough stuff man, haha. My turbo is shipping back to me today from being rebuilt. I'll work my hands behind the intake tonight to try and secure it a bit. Thanks!
__________________
LS1Tech Sponsor
Slowhawk's Avatar
Tap the old MAP hole with a 1/4" pipe thread.Screw in a barb fitting and run a 1/4" hose to the MAP sensor.Thats a permanent fix and we do it all the time on FAST intakes.
Old 05-17-2007, 05:24 AM
LS1Tech Sponsor
Superman09's Avatar
But then where do you mount the MAP sensor?
__________________
Old 05-17-2007, 11:15 AM
HUNTER02SS's Avatar
All you do if you use the tap and barb setup is run a little short vacum hose from the barb that is now on the intake to the vacum nipple on the bottom of the map sensor.You will take the rubber grommet off of the bottom of the sensor first and the attatch the vacumm hose.
Old 05-17-2007, 11:25 AM
LS1Tech Sponsor
Superman09's Avatar
o ok, and just have the sensor dangle back there? Maybe i'll do this...!
__________________
Old 05-17-2007, 09:20 PM
HUNTER02SS's Avatar
Yes, I have the victor jr intake and had to run the vacum hose to it like that,and it is just sitting back there along for the ride.
Quick Reply: Do i need to worry about MAP sensor?
