Wtf Plese Help !
Wtf Plese Help !
I just installed pacesetter l/t and ory on my 2000 t/a and it sounded good the first day but then today I noticed a kind of grinding sound when i push on the gas or turning sometimes. At idel it sounds fine, but then when ou try and go it sounds horrible..PLEASE HELP !!!!!!!!!
Maybe it's a loose part vibrating?
(I spent 1/2 day at Mufflex while they diagnosed a weird high-pitch "grind" type noise at certain engine RPMs, turned out to be a plate on the exterior of the muffler had popped a weld)
Did you check over the k-member really well? Thats where my pacesetters were rubbing. Everytime you took off it would rub and make a grinding like noise as the header scraped agaisnt it.
If metal is rubbing, there's a shiny spot somewhere waiting for you to find it.
Or, just loosen up all the joints in the exhaust system and push the pipes way far away from any nearby body/chassis components.
