~~~Trans Will Not Shift Into Third!!!!~~~
UPDAETD THREAD ~~~Trans Will Not Shift Into Third!!!!~~~
well was driving this morning and was normal cruise not on the gas much, i just woke up so i was still outta it and not really in a mood to go fast, but the car drove fine for about 5 miles. Then i leave a stop light and it will not shift into thrid at all. Revs forever and will not shift. I noticed in the last 2 days that the car was gradualy not shifting all that great, but being that i have a 4000 stall and a small trans cooler on it, that it does get hot. And livign in Florida doesnt help. I did have somewhat of this problem before and i drained the trans fluid and put fresh fluid in and it ran great up till now, that was about 7-8 months ago i think... maybe more.
Any Ideas On what can be causing this??. The guy told me it was a stage 2 trans to handle 700hp. I have 330hp/336tq so i dont think its a power issue.
Thanks in Advance
*EDIT* pics added
Originally Posted by performabuilt
Yes it does sound like the 3-4 clutch may be failing
LS1Tech Sponsor
From looking at the chart you posted I would at least try the 2-3 soleniod and I see you also have a PCS code in history so you might consider replacing that also and while your in there look in pan and if there alot of gray matter then start saving for a trans.
__________________
yeah the PCS is a stupid code from like 2 years ago that i cant clear.... back when i originally broke my trans into 22,683 pieces give or take a few. But yeah so im going to replace the 2-3 solenoid then.
WHERE CAN I GET A 2-3 SOLENOID??, and i know what everyone will say a sponsor...lol but exactly how much and where and which one should i go with being that i have a 4000 stall.
thanks in advance, and thanks to all for the input
Originally Posted by 02NHRAtransAm
My 01 SS did the same thing to me. Third was there then it wasnt. Lost the 3-4 clutches hope you turn out luckier than i did
From the looks of the pan it don't look good.
You have my sympathies. I have been there too.
Luckily I have the luxury of letting mine sit until I can fix the problem.
Good Luck.
Good Luck.
Originally Posted by spec_j
i hope its not that, i cant afford to buy another trans. $2700 on the first two were horrible and the budget wont allow for a rebuild again. so i guess if thats the case, i take it to the dealer and trade it
okay, I changed the 1-2, 2-3 silonodes (sp) it didnt fix it. BUT, I command 3rd only in HPT, and i was able to drive it in 3rd up to 45 or 50 mph. ALSO, I I command the 2-3 selonoid (sp, again) only and it started in 2nd, shifted into 3rd for like 1 second, then it went lose again.
Originally Posted by gator's 99TA
call up fernando. he is the only honest transmission builder in this area. good luck. i feel ya on the 4L60e rebuild costs. honestly you arent even beating on it yet!
