S-10, quick questions
Alright guys, I've got a couple quick questions for some of you with experience. I recently came upon an s10 with a rod knocking, and I want to put a v8 in it (preferably an lt1 or cheaper for cost reasons). It's a 2wd 4 cyl, what are my options for motors to put in it, and about how much would it cost to get running? I don't plan on any major go-fast mods yet, I just want to get it running first.
BTW, I want to keep it streetable, but I wouldn't mind building it for mid-high 11's. Also, my DD Talon is fully gutted and has a 6-puck clutch, so I don't really mind those minor inconveniences for a daily driver.
check these sites out
www.lt4blazer.net
www.s10forum.com
www.s10v8.com
www.v8s10.com
www.v8s10.org
www.cameo.com
all of these sites have PLENTY Lt1 installs
www.lt4blazer.net
www.s10forum.com
www.s10v8.com
www.v8s10.com
www.v8s10.org
www.cameo.com
Originally Posted by shifty`
www.lt4blazer.net
www.s10forum.com
www.s10v8.com
www.v8s10.com
www.v8s10.org
www.cameo.com
www.lt4blazer.net
www.s10forum.com
www.s10v8.com
www.v8s10.com
www.v8s10.org
www.cameo.com
Cheapest would most likely be a Vortec 350 from a 96-99 truck/SUV or 96-'02 Express van.
You are at a disadvantage starting with the 2.2 for cost reasons, but it is still probably the cheapest.
Not going to get you 11's though
Originally Posted by BoOsTeDeAgLe
Ok that was one of the setups I was wondering about, thanks.
Cheapest is an old 350. You can't build anything cheaper than a carbed 350, and depending on what you want to spend on it, you can get some serious HP. Nothing fancy here, get a cooling system setup, make some motor mounts, add a TH350 or a 700R4, run a fuel line at 6psi (could adapt your current pump assembly using an aftermarket regulator and the return line), Connect the distributor, starter and alternator and you are off to the exhaust shop. Maybe not the coolest swap, but there are TONS of books and sites about adding a GEN 1 SBC to an S-10.
Any clutch recommendations, I'm not sure what will fit.
Also, what rearend should I go for? I will probably be spraying around 300, so I seriously doubt a 4.3 rear will hold up very long.
