Tech Help needed!! Please Help
Old 05-17-2007, 09:49 AM
Nitro Dave's Nitrous Outlet's Avatar
Default Tech Help needed!! Please Help
I need some help from anyone that may know.
I bought a 97 Chevy single cab that was slamed to the ground.
Here is what was on the truck.
All Parts are DJM
Front
2" Drop Spindles Part# DJM-DS20562
3" Drop Springs Part # DJM-CS23513
DJM Shocks Part# DJM-1315
Back
4/6 Flip kit Part#DJM-FK10256
With Rear shackle
Ok I wanted to raise the truck to a 2/4 drop so on the front I put the factory springs back in it.
On the back I fliped the rear end back and removed the flip kit. Then installed a hanger and shackle kit. Part#DJM-HS11214
According to DJM this is the correct way but the truck is really high in the back and low in the front. I do not know exactly whats wrong.
It will have alittle rake do to the front tires being shorter.
Rear tires= 275-60-R15
Front Tires= 255-60-R15
Here is what it looks like.
Pictures of Rear end set up.
Any insite will be appreciated.
Thanks
Dave
Old 05-18-2007, 09:50 PM
chevysol73's Avatar
i would think a shorter rear shackle [your last pic] would fix your problem?
Quick Reply: Tech Help needed!! Please Help
