help! problem with 3rd gear
Old 05-17-2007, 02:27 PM
bigmike_ws6's Avatar
Default help! problem with 3rd gear
basically when i go to shift into 3rd it grinds and vibrates..unless i push really hard then it makes a loud "knock" sound but then stays in gear and works perfectly..i went to a mech. shop and they siad its a bad synchro ring..like 400-500$ to fix..after reading up in here tho it seems it could also just be something with the shifter itself..bent fork? etc..any sugestions??
Old 05-17-2007, 03:51 PM
Oneslowz28's Avatar
Either fork or syncro the trans has to torn down to fix. If you end up getting it done get the hardend shift fork.
