~~How to replace 2-3 Solenoid??~~
HELP ME!!!!
i need to change the 2-3 solenoid, and i DID use the search feature but the only other person that asked didnt get a reply. write up, pictures, vid, anything would be great.
Thanks in advance....
If you care, the one right next to the Fwd Accum Cover is the 1-2, the 2-3 is next in line, then the plugged accum valve bore, then the Pressure Control Solenoid. As others have said, the 1-2 Solenoid and the 2-3 Solenoid are identical part numbers.
