Torsen T-2R strength vs Eaton strength
I know this probably belongs in the gears and axles section, but I figured since most people are focused on handling in here this would be the place to get answers. I have a 10 bolt with 3.73's in it and an eaton posi, and I never had any problems with it doing a 1 wheel burnout or spinning the inside tire around the turn, and I always liked how it worked. Then thursday I was doing a normal rear end oil change and I found a tooth off a spider gear in the bottom of the housing. It would cost me about $250 for new spider gears if the clutch packs are ok. I kind of hate doing this, but it would be the cheapest route without dumping too much $$ into the 10 bolt just to break it again a year later. I'm also considering a T-2R since I plan on doing some road coarse driving events in my car, but if it isn't any stronger than the eaton, I'm not going to spend $550 on it just to break it a year later expecially since its not rebuildable. And what normally causes the spider gears to break, launching it or powering out of turns?
I would probably put a T2R in my 10 bolt if I didn't want 4.10 gears, with my 400/381 setup. I don't do any hard launches really. The only launches I do are on 315 drag radials on poor surfaces
Sam's also recommended the Auburn Racer's diff as of late since I think he won a nationals event with it. Probably will be the road I take.
Originally Posted by DONAIMIAN
Have you looked at the tru-trac? I think it has a nice price tag on it.
LS1TECH Sponsor
You know, I sell all of the above. Torsen, Eaton, Auburn, TruTrac's (and others). And BTW, you need to know there are different "levels" of Torsens and Auburns.....
I can't recommend anything (more like won't) without talking to you first. I need to have a better idea what the deal here is. T2R's aren't meant to be drag raced but rock around corners.
Happy to help, can't do it by e-mail. Sorry.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Robert I presume? You're about 2 or 3 down my list (don't worry, I didn't forget). Just had a few supplier issues I needed to work out first. I'll give you a call today.
__________________
