Centerforce Dual Friction
Old 05-20-2007, 01:49 AM
71-Camaro-98's Avatar
Default Centerforce Dual Friction
What to you guys think of the Centerforce Dual Friction Clutch? Is it a good clutch for a daily driver? Let me know what you think...
Old 05-20-2007, 01:56 AM
skeels's Avatar
Ive had mine on for about 15k miles and its still holding up. Good for a DD, feels stock. Mine sticks occasionally when powershifting, but then again i havent gotten around to heat wrapping / drill mod so that will proboly fix it. Mine does however have quite a bit of chatter in reverse. Take it how it is, just my 2 cents with it. BTW, ive got a 01 ws6 with boltons.
Old 05-20-2007, 01:59 AM
gametech's Avatar
under 450rwtq=OK. Above 450rwtq= disaster. CF dual frictions are good for mild bolt-on cars. Beyond that, choose a better clutch.
Old 05-20-2007, 05:47 PM
wannafbody's Avatar
I talked to a guy who swears by his centerforce clutch. Says it is much better than the stock clutch. Do they make more than one version?
Old 05-20-2007, 05:53 PM
skeels's Avatar
The Centerforce DF is better than stock (assuming its an f-body and not a C6 Z06 or something). Would be good for an almost stock car with a few boltons, but once you start making a little bit of power is when its starts going downhill.
Old 05-20-2007, 08:41 PM
01black's Avatar
they make two diff ones though...in their catalog they show one for high boost/nitrous applications....?????
Old 05-20-2007, 09:14 PM
SR-71 SS's Avatar
Mine died on the dyno at 550 rwtq, other than that at lower power levels it was a nice clutch, pedal felt the same as the z06 clutch I had before it, no chatter, no hassle. Its just not up to big power numbers.
Quick Reply: Centerforce Dual Friction
