Gears & Axles - Diff oil refill????? HELP PLZ
losaltos6
05-20-2007, 07:51 PM
Hey guys so how can i fill up my diffrential with fluid, is there a hole because it seems akward to just drop fluid in.
camarolvr69
05-20-2007, 07:59 PM
you have to get a pump to siphon it into the diff. Wal Mart and any local parts shop will have one. They run for ~$10.
:drive:
koolaid_kid
05-20-2007, 08:14 PM
It is on the passenger's side of the differential, and takes a 3/8" ratchet to remove/install.
skeels
05-21-2007, 08:04 AM
I just got a 4" peice of tube or so and squeezed the bottle till it was full. Or you can use the pump method.
Hugger Z
05-21-2007, 09:30 AM
I use the tube method into the pass side hole until it dribbles out. Then stop, cap it off, and wipe everything clean. Gotta love that diff fluid stench! Ha ha.
BlackScreaminMachine
05-21-2007, 12:32 PM
I think they should make a cologne, "Differential Fluid" for the manly man inside of all of us. lol
losaltos6
05-21-2007, 12:36 PM
ok all done i did it, i still think i should have scraped everthing of the the cover, i left a bit on there since i could not take it off without scratching the surface. just a bit thow.
camarolvr69
05-21-2007, 02:41 PM
bet it drives smoother now...
:drive:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
