Passenger Squeak
Old 05-21-2007, 09:10 PM
Nasty99TA's Avatar
Default Passenger Squeak
When I'm cruising around at 40+ mph my passenger seat starts to make a annoying squeak like it is coming from inside of it possibly a spring or something i know this happens alot but what do you recommend doing?
Or could it be coming from a totally different place?
Any help would be appreciated.
-B
Old 05-21-2007, 09:13 PM
skifast87's Avatar
LOL i have never heard of this. I don't know what to tell you on this one. Make sure its bolted down the whole way. Uhhhh put some books in it. I really don't know man
Old 05-21-2007, 10:43 PM
Nasty99TA's Avatar
hmm im going to try to tighten everything thing down tonight if that doesnt work then iunno hah
Old 05-23-2007, 02:17 AM
HossinatorSS's Avatar
mine does it only when somebody is sitting in it though
Old 05-24-2007, 09:37 PM
Hoss Ghoul's Avatar
Make sure the seatbelt bracket on the passenger seat is tight, lots of squeaking comes from there.
Old 05-24-2007, 11:40 PM
ghardester's Avatar
I'll say that it is not the passenger seat but the passenger side rear seat where it latches in the upright position. Check that. Or check the spare donut tire compartment.
Old 06-11-2007, 01:17 PM
Lonewolf 1's Avatar
Default Same issue
Nasty, I'm having the same issue with my ride...only squeaks when someone sits there...figured anything out?
Old 06-13-2007, 12:59 PM
SmaknaSS's Avatar
I found that my squeeks were from the springs underneath the seat(The ones used for ajusting the seat)were rubing agaist the seat frame(metal to metal). I installed heat shrink over the springs as a temporary fix and the problem has not come back yet.
Old 06-14-2007, 02:40 AM
Relapse's Avatar
Mine has the exact same problem, **** squeaks when i'm driving at around 60+ non-stop.. seems like it's a spring of some sort.. probably an old worn out one, but it drives me crazy
Quick Reply: Passenger Squeak
