LS7 Clutch
Old 05-21-2007, 09:29 PM
Blu99T/A's Avatar
Default LS7 Clutch
I acquired a complete T-56 setup to convert my A4. I was told the LS7 clutch, pressure plate/LS7 flywheel all have around 5000 miles on them. The clutch looks to be in really good shape except the inner springs. 2 of the 4 inner springs (the yellow springs) rattle pretty good. They seem really loose inside the bigger outer springs. I have never dealt with dual spring clutches and have no idea if this is normal or not. I would like to use this clutch but will buy new if I have to. Feedback please.
Old 05-21-2007, 11:51 PM
Mike94ZLT1's Avatar
The LS6 clutch and pressure plate are not compatible with the LS7 flywheel. Post some pics so we can see what you have.
Old 05-22-2007, 08:07 AM
Blu99T/A's Avatar
My bad, that is a typo. I have the title right. I def. have an LS7 clutch, pressure plate and flywheel. I just need to know about the springs in the clutch.
Old 05-22-2007, 08:29 PM
Blu99T/A's Avatar
Anybody know this about the springs?
Old 05-23-2007, 12:42 PM
Blu99T/A's Avatar
TTT Would like to find some type of answer before I install it this weekend.
Old 05-23-2007, 06:16 PM
SIC LSX's Avatar
bump i saw this to and is a little yellow spring inside another spring and its not hooked up to anything! The little spring is just in there loose moving around and not hooked up to anything!
Old 05-25-2007, 10:06 PM
TurboDan's Avatar
I just checked my brand new LS7 clutch plate and the yellow springs are loose and rattle around inside the outer springs. My guess is that this is normal.
Old 11-13-2007, 09:09 PM
PonchoLS1's Avatar
Anyone know why this is? Mine just arrived from SDPC today, and when I picked up the disc, I was quite surprised by the rattle of one pair of inner springs!
Old 11-14-2007, 02:53 PM
Hugger Z's Avatar
I am not sure what they do. But maybe they are loaded up when the clutch is spinning. Mine makes no noise on the car or while driving so I would not worry about it.
Old 05-01-2008, 08:48 PM
SUTTERERMAN85's Avatar
i bought a new one today and noticed the same thing with the 2 yellow springs...how can this be normal? is the disk making any noise? i dont think i am going to put it in like that. my LS7 i took out isnt that way either....
Old 05-01-2008, 11:22 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Damn this is an old thread
Mine was the same way and never had a single problem or noise with it
Old 05-02-2008, 08:02 AM
ok well i guess i am going to run it then...
Quick Reply: LS7 Clutch
