What Kind Of Bulbs Are Behind The Gauges On 4th Gens?
Old 05-21-2007, 10:21 PM
transambrotha's Avatar
Default What Kind Of Bulbs Are Behind The Gauges On 4th Gens?
What kind of bulbs and how do I take the cluster out to put the bulbs in? Anybody done this before?? Thanks, Mike
Old 05-22-2007, 09:58 AM
tylerdj's Avatar
Bulbs are 194's, Just pull of the bezel around the gauge cluster and you'll see 4 small bolts holding the cluster in. Remove these and the cluster will just pull out. You'll see several black things on the back of cluster, turn these and pull out and you'll find the bulbs.
Old 05-22-2007, 02:55 PM
thanks, I'll do that today. Also, how does the fog light switch come off of the bezel, I don't see where it does without breaking it
Old 05-22-2007, 08:29 PM
TORCHD 02 TA's Avatar
the bulbs are 194s. the fog light switch has a male/female end that you need to unplug. it is wrapped around with foam padded tape
Old 05-24-2007, 05:00 PM
5PONT7's Avatar
could i just change the bulbs to make my cluster red other than white?
Old 05-24-2007, 10:15 PM
are 194's the same for the steering wheel radio control lights? and how do I take the steering radio controls out?
by the way, I changed my gauge bulb and it worked great, thanks everyone for the help
