Nitrous Oxide - Power to Nitrous and accs.
John Junkins
05-22-2007, 04:41 PM
Can I use the spot in the fuse box inside the car marked IGN to wire my complete nitrous kit from the purge, bottle heater, bottle opener, traction/RPM Control and the Zex kit itself. If I use a fuse link before the Nitrous Dave ashtray switch? Any help would be greatly appreciated.
Thanks,
John Junkins
Noyzee
05-22-2007, 05:15 PM
i wire right into the acc port in that box. just get a femake connector and tie one heavy ga wire to it to get you down by your feet, then solder like 5 smaller wires to that and use those to run everything. it works out well but i usually bump the fuse up 5 amp
John Junkins
05-22-2007, 05:20 PM
Noyzee,
I'm using the Acc port for my AutoMeter Gauges. Could I also use this for both? Also do I need any relays in the system, the diagrams don't show any.
I thought this was going to be so simple.. Thanks for the help
John Junkins
Noyzee
05-22-2007, 05:24 PM
Noyzee,
John Junkins
yhea, wire them all right to them.
you need a relay on the heater and on the main power for the noids depending on what your using to activate the system.
i use one on my purge for the race car, but only because i dontwant to blow a fuse right befor a race
John Junkins
05-22-2007, 05:27 PM
Noyzee,
Did you wire it from the front with a connector or from the back with a splice connector. Maybe I can get this done before the weekend. This is really helpful.
Thanks Again,
John Junkins
Noyzee
05-22-2007, 05:34 PM
Noyzee,
Thanks Again,
John Junkins
hell no!!!!!!!!!!!!!!!!!!!! never ever use those shit connectors!!!!!!
right from the box. femail connector coming out solder it all up nice with shrink wrap ect. no butt conectors and stuff. do it right the first time and it will all work
John Junkins
05-22-2007, 08:09 PM
Noyzee,
I understand that, I really appreciate all the info. Hopefully I will have this done by the weekend if not like you said I only want to do this once and the right way.
Thanks Again,
John Junkins
jares99
05-22-2007, 08:24 PM
Noyzee do you run your main power for the relays from this or are you still taking these to the battery or main power with an inline fuse still or do you wire everything to the fuse block?
Thanks
Joel
Noyzee
05-23-2007, 07:43 AM
Thanks
Joel
my relays for main power and heater come off the batt.
i run the switch power from the box.
jares99
05-23-2007, 05:47 PM
Ok thats what I was thinking you were saying I didn't think the fuse block would have enough power.
John Junkins
05-23-2007, 06:58 PM
Noyzee,
I run the switch power from the box.
I'm confused?? On what I'm suppose to do. I've already installed it from the fuse box with a fuse link to the the Ashtray switches for Zex management unit, Purge, Bottle opener and Bottle heater. With leads ran to the areas and was going to just hook them up. Is this right or wrong??? PLEASE Let me know.
Thanks Again,
John Junkins
Noyzee
05-24-2007, 08:16 AM
Noyzee,
Thanks Again,
John Junkins
your main power should come off the batt for heater and main power.
your switched 12v should come to your box.
give me a list of what you are running and i will make you a verbal sequence of operation.
what WOT are you using, heater, purge? ect ect.
i will try to explain better.
or check out this thread, it may answer your questions.
http://www.ls1tech.com/forums/showthread.php?t=501965&page=2&pp=10
John Junkins
05-24-2007, 02:02 PM
Noyzee,
I'm using the ZEX wet kit, ZEX Bottle Opener, ZEX Bottle Heater, ZEX Purge and the ZEX Traction Control. And I what a Nitrous Dave ashtray switch with the 4 buttons for the above ^^^^^. That's it your help is greatly appreciated.
Thanks Again,
John Junkins
Noyzee
05-24-2007, 02:52 PM
i will try to sit down and make the order up tonight when i get out of work.
did you check the thread above? all the info is probable in there someplace. if not, i will try to get it down tonight.
Noyzee
05-24-2007, 02:58 PM
check this out. this should get you started.
http://i73.imagethrust.com/images/1V6w/view-image/complete.html
John Junkins
05-24-2007, 05:59 PM
Noyzee,
My activation and safety switch is in the Zex Management box. And only one wire is to be hooked up to the switch 12v. Your help is greatly appreciated. I'm just about ready to take it back off and just sell everything. I thought it was going to be the easy way to get more HP. WRONG. PLEASE let me know
Thanks Again and I owe you one,
John Junkins
Noyzee
05-25-2007, 08:01 AM
Noyzee,
John Junkins
everyone thinks its easy, but without knowing wiring it is a pain in the ass.
i never did a zex kit, but if it needs switched 12v and it is activation and managment, i believe you can power it right from the fuse box.
i would guess you need to go from the box to a switch, then to the zex box.
did it come with instructions? if it did, scane them so i can read them that will help, like i said i never messed with zex
John Junkins
05-25-2007, 02:34 PM
What about the ZEX bottle heater, It has a built in thermostat that turns it on and off Automatically. And again only one wire to hook up plus the black ground. and the ZEX Traction Control hooks up to most of the ZEX management box and one wire goes to a const power I guess the back of the Alternator? And would I need to use any relays?
Thanks Again have a safe holiday,
John Junkins
John Junkins
05-25-2007, 02:36 PM
Noyzee
I will also scan my paper work for the complete kit and send it to you
Thanks again for your help.
John Junkins
Noyzee
05-25-2007, 02:41 PM
John Junkins
this will help alot!!! check out this link
http://i73.imagethrust.com/images/1V6E/view-image/word-zex-fpss-and-window-single-stage-tps-breaking.html
Noyzee
05-25-2007, 02:51 PM
John Junkins
without knowing 100% i belive
heater goes
Battery to a fuse.
fuse to 30 on a relay
switch to 86 on relay
87 to heater
other wire on heater to ground
John Junkins
05-25-2007, 06:23 PM
Noyzee, I think I have it figured out with the info you gave me. If not I will be in touch. Thanks Again for all the help it's greatly appreciated.
Thanks Again, have a safe holiday weekend and God Bless Our Troops and the U.S.,
John Junkins
Noyzee
05-27-2007, 12:29 AM
glad i could help. wish i could have done more, but i have yet to mess with zex.
good luck bud
