Did Wire Mod...Car Has NO Power! Need Help!
I did the wire mod a week or so ago...and today I just got my battery back in the hot rod to crank her up and I got no interior lighting guages or anything. ZERO power to the car.
Where should I start checking?????...I have a total of 7 grounds that I can count that are grounded...Could the connectors that I took apart and put back together, (which I know are connected to the correct connector because I marked all of them) have something to do with this or is this strictly a bad ground or positive?
Please shoot me some input and feedback, so maybe I can go through a check list tomorrow and figure out what I have wrong.
TIA
TIA
-Check your battery / its connections first. It's the easiest.
-Then check your ground connections that you disconnected, and ensure they are making good contact / are placed back into the right place.
-I know how bad trouble shooting can be (EE Major), but if the previous doesnt work, you are probably going to have to go through and check every connection.
Originally Posted by toofazt
Is your battery dead?
- I did do some relocating of some of the grounds, but all seemed to be tied up correctly. It was getting a lil dark outside once I finally got around to starting the car and checking for issues so maybe I will find that one of the grounds have started working their wire off of the connector.
I just seriously hope I dont have to go back though my wires that I relocated under the fender because me and my buddy made a plate to further protect the wires and tack welded it underneath and it will be a major PIA to take off. Hence my stupid *** mistake to not check all of this right after I did the mod before I made the plate, but I was into completly sanding down and painting my engine bay, so I was distracted away from it doing so directly after...
It seems with the few respondses that it may just be bad ground or pos. which is a plus but always a PIA to trouble shoot stuff like this...
Wish me luck fellas, and anyone else with some feedback...please respond!
It was a pretty wide plate that left quite a bit of space on each side of the wires, and I already had them mummy wraped in electric tape, so on that Im not positive that I didnt but I really dont think we did...We didnt get to intense with the welds just enough to do the job...
Ill make that check tomorrow when I have some good lighting...I sure damn hope I didnt!
