Tachometer calibration, is it possible?
Old 05-23-2007, 06:58 AM
trexbob's Avatar
Default Tachometer calibration, is it possible?
My tachometer reads too low, anywhere from 300-350rpm too low at idle (car idling at 750, tachometer reads around 1100), and even higher up it's still around 200rpm off. I know it's doing it because I've had a scan tool with tachometer hooked up, held the rpm at certain speeds on the scanner, and looked at the tach. The speedometer matches the scan tool perfectly, but is there a way to calibrate the tachometer? It really bugs the heck out of me to know it's that far off.
Old 05-23-2007, 11:35 AM
staringback05's Avatar
what kind of scanner are you using?....efi live can change it i believe, the stock gauges arent exactly on...they are sometimes off by several hundred rpms...
Old 05-23-2007, 12:24 PM
Adrenaline_SS's Avatar
You could pull the needle; rev to a set RPM with the scan tool and just put the needle on the appropriate #
