Head Casting Number ?
I want to have a set of heads ported by a guy here in town. What are the best casting numbers to use as a base for ported heads? Thanks in advance guys
i got ARE P&P #241 heads. but they came with my motor from speed inc. anyone know how much power those would be worth comapred to the 243 castings?
heres STOCK head casting #'s and info
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Even more info:
Casting Number 241
Part Number:
12559853 (1997-98)
12564241 (2001-03)
Casting Number 243
Part Number:
12564243
Casting Number 706
Part Number:
12559852
12561706
Casting Number 373
Material: Cast Iron
Part Number:
12561873
Casting Number 317
Part Number:
12572035
well like i said agustino raceing did it. they sued to be really big back when the ls1 first came out then they split. fraser at speed inc said they should be pretty good, but im wondering how good.. I wanna put down 400rwhp+ with my 228R cam and the more the merrier!
to the OP: hope that head info helps ya some!
numbers are numbers man.....dont so much worry about your power as what you can do at the track....you want to take the stall out and be the guy who says hey look i made huge numbers....but my car is slow
or do you want to be the guy who makes 380 and runs 11s?....not to say you still wont be above 400, your not going to lose that much
Thanks for the replies guys. I am running the msv4 and I am wanting ported heads. I just wanted to know which stock heads would be the best to start a port job on. I have a local guy here that says he can do excellent things with the 243 castings so I will go with those unless there are some that flow close to those for cheaper
