radiator hoses in 1st gen
Old 05-23-2007, 05:01 PM
working4toys's Avatar
Default radiator hoses in 1st gen
Anybody use the stock-type 69 radiator with their ls swap? I cant find radiator hoses that fit. Any suggestions. Last thing before first start so im kind of getting anxious.
Old 05-23-2007, 05:03 PM
Couldnt find anything specific in the search or stickys.
Old 05-23-2007, 07:40 PM
67rsss's Avatar
We are using the 02 radiator in our 67. We haven't tried our hoses yet. I don't know what you would use with the first gen radiator. I would suggest you make a coathanger template and spend a bit of time at Napa....
Old 05-23-2007, 09:12 PM
Rodder's Avatar
I'm using a '68 radiator and '68-length flex hoses from VatoZone in mine right now. I need to redo the hoses--they're pretty nasty looking, a little too big on the LS1 side, and the lower hose is in danger of kinking.
Old 05-24-2007, 09:59 PM
thanks rodder
Old 05-25-2007, 02:04 AM
ls1canuck's Avatar
I used a '05 tahoe upper hose and just cut it down. If you get the lower rad inlet resized at a rad shop to match the size of the LS1 you can use a '00 Camaro lower hose. With those two hoses the setup looks stock. I don't like those universal hoses if I can avoid them.
Quick Reply: radiator hoses in 1st gen
