Question On 6.0L Heads on a 346 ????
I got some ported and polished 6.0L heads with bigger valves from my buddy. I have a stock bottom end 346 with a 232/234 cam. I know that these heads are a little big for my car. Speed INC said these heads on a 346 would lower my compression to about 9.1 and that it would run like *** N/A. Is the compression to low to spray nitrous? Should i put the heads on or not? Thanks
You guys are jumping the gun, what is his chamber size?? They are allready ported, perhaps the are welded 6.0s with smaller chamber (Like PP LS6 style), those are 6.0 castings.
If these are milled 71cc heads then PTV should be measured for that cam. That is like ~ 4cc mill or .025
The 232/234 if on 113 "should" clear and if 112/112+2 or 112+4 better measure on intake side just to be sure.
Originally Posted by TA2SLOW346
If those are my old heads they are 67ccs
Thanks for all the help
Yes they are your old old heads. So would i be fine swapping them since they are 67cc or would it lower the compression to much? The cam is the Torquer 2 i was going to go with the 112 but should i go with the 113 instead. So these heads are milled -4 degrees?
I would pick a cam that can fit with a tight LSA to maximize your DCR.
Like a 227/230 .629/.612 112+2 (LSK/XFI) lobes from Comp cam (Custom order)
Originally Posted by Mike94ZLT1
If a 6.0 liter has a 4" bore and you can put 6.0 heads on an LS1 with a 3.9" bore, why can't you put L92 heads on?
Heads where milled .040 But the sides of the chambers where opened up to fit a 4.100 bore i used to run
