New lifters/parts cleaning/lubing before install?
Old 05-24-2007, 03:41 PM
stealth71's Avatar
Default New lifters/parts cleaning/lubing before install?
I want to throughly clean all my new internals before I install them. Most of it is straight forward. I figured just some brake cleaner and a rag. What should I do to clean the lifters? They are new and have some dust and stuff on them. Should I just wipe them down or soak them in something? I just want to make sure everything is as clean as possible.
Also I bought some assembly lube to coat stuff with because, the motor will sit for at least a couple weeks before it's started. What should I coat w/ it and is there anything I shouldn't coat. I was planning on putting it on the lifters, cam and possibly the timing chain.
Do I need to soak the lifters in oil before install?
Any input?
Old 05-24-2007, 04:47 PM
BIG_MIKE2005's Avatar
Yes soak the lifters first.
Old 05-25-2007, 08:58 AM
jmm98LS1's Avatar
Clean the lifters with mineral spirits & let dry completely, then soak them in oil--I usually soak them for a day or two. (probably overkill)
Old 05-25-2007, 09:27 AM
radkon's Avatar
+1 but a day is a bit of overkill. Minimum of 30 mins but the max is up to you.
Old 05-25-2007, 11:17 AM
stealth71's Avatar
What about assembly lube on the cam and lifters? Should I put a little on the roller and lifter body to protect it during initial startup?
Since the engine can't be primed easily without rotating it, like an old school SBC. I just want to make sure it's all safe as possible.
Old 05-25-2007, 12:23 PM
PAGregSS's Avatar
You really don't need the moly lube on the lifters. Only put it on the mains on the cam.
Old 05-25-2007, 04:50 PM
AutomagicLS1's Avatar
Make sure you clean the deck of the block and heads with lots of lacquer thinner it will take that old gasket **** off real quick. 1 thing i messed up was I forgot to tighten that bolt that blocks off the temp sensor port on the passenger side head. When I fired it up it was leaking and if you have big hands its a BITCH to get to atleast for me
Quick Reply: New lifters/parts cleaning/lubing before install?
