rear brake bracket
rear brake bracket
Built the rear and am putting the car back together.
I need the torque spec for the rear brake caliper bracket to rear end bolts. The service manual says 166 ft#'s but the bolt broke before I got there. I didn't reused the original bolts service manual says they are one time bolts, I used new bolts of the same grade (10.9)
I tried searching but it wasn't working so well.
I see this post is a couple days old but if you still need the info I can look it up when I get home. I reused my original bolts I cant see having to replace them. From what I remember it was around 70-80 ft lbs or so its the front ones that are a lot the fronts were 126ft lbs I believe. 166 is wayyyy too much for the rear ones.
