outside noise coming from top of door
Its coming from somewhere around my head. is there anything i can do to fix this? my weather stripping looks fine from the outside. i normally wouldn't mind but i just spend 30+ hours and hundreds of dollars sound proofing my car. it sounds almost as bad as the window open a few inches. anyone else have this problem? is it common.
also check to see if the skin of your door has separated from the frame...just tug on the handle with the door locked and watch for movement.
If it has separated then it wont press the window against the weather stripping and make a seal.
okay well i can see the weather stripping is going bad. so i cut a small slit in it and im filling it with silicone. working good so far. i just need to buy another small tube and i should be all good.
