Headlight problem. Low beam.
Figured I would post this hear and maybe get some help. My driver side headlight motor went out so I switched it out with a new one. After I did that the low beam light does not work. Switched back to the old motor and again doesn't work. It gets power, has a good ground, and bulb is good.
My high beams both work but only the driver side low beam does not work. My fog lights also do not work.
WTF is up with this junk?
Originally Posted by chavez885
so neither motor works and the bulb IS good...not sure,anyone else?
So I buy a new low beam light and that doesn't work. It's getting power, it has a good ground but it doesn't work.
mine did the same thing when i changed mine out all i did was kept switching from low to high beams and it finally came on. now will it work for you i dont know but its worth a shot.
