Welding oil pan on the block
Is it safe to weld my oil pan while it is still bolted to my block? Its an LS2 and I planned on leaving it bolted to try to keep it from distorting. I have the harness removed is there any other precautions I should take? Should I remove the oil pan gasket and bolt it to the block would that also help to keep it flat?
If you had no other flat surface you can do this. You do have to take off the gasket, though. The heat generated from the welding will disipate fast enough as to not hurt the block. Make sure the pan is completely clean, aluminum is very hard to weld when it's dirty.
