What to use to remove oil stains in garage?
Old 05-26-2007, 09:28 AM
kaos_'s Avatar
Default What to use to remove oil stains in garage?
Well, I set down the oil pan and somehow it leaked all over the floor overnight. I discovered a crack at the bottom. I tried using some brake clean to get it out, and while it did work some I need something a little more heavy duty. what do you guys use?
Old 05-26-2007, 10:28 AM
skifast87's Avatar
Honestly i just use some cat litter / sawdust you gotta let it sit for a long time but it seems to do the trick
Old 05-26-2007, 10:37 AM
thecorrectformula's Avatar
Go to any auto parts store and tell them you need floor dry. It's kinda like cat litter and not to much more expensive, but it works way quicker. Just spread it on the floor let it sit for 5 minutes or so and sweep it up with a good shop broom. It should remove almost all the oil and grease. After that if you still need to just use some soap and water and a mop.
Old 05-26-2007, 11:09 AM
kaos_'s Avatar
that will work even after the oil has soaked in to the ground?
Old 05-26-2007, 11:24 AM
Shock Hawk's Avatar
It's real cheap and it's probably going to work better than pressure washing.
Old 05-26-2007, 12:01 PM
Yeah the stuff is amazing. I go to Wyotech and we use a soap version of the stuff on the floors usually every friday and the floors still look brand new.
Old 05-26-2007, 12:10 PM
navy02ws6's Avatar
Yep, Oil-Dry, comes in up to a 20 lb bag I believe, and the stuff works wonders. Plus it's less than $5 at Pep Boys.
Old 05-26-2007, 01:09 PM
styoung's Avatar
ya oil dry we use that a work, soaks up hyd. oil, cutting oil, and whatever else we spill, and like said before is cheap.
Old 05-27-2007, 10:59 PM
2001 WS6 SOM's Avatar
Kitty litter and other absorbants work good for spills but if the stain is in the cement. Use a thing called TSP, you should be able to get it at most hardware stores (usually paint dept). Its used to remove oil to prep surfaces for paint. Comes in a box like a milk carton (white). Wet the floor, add some of this, scrub and rinse... Works amazing, and its cheap.
