Question on a Cam
Question on a Cam
I think I made a mistake but I hope I didnt.
Gut feeling I did but can a VooDoo 268 Part #60103LK be used on a 99 LS1 out of a Camaro SS? I looked it up at the local auto parts store and this cam was offered under performance cams but after reading around I havnt found any info to support it can be used...
Please tell me I didnt F**k up...
Gut feeling I did but can a VooDoo 286 Part #60103LK be used on a 99 LS1 out of a Camaro SS? I looked it up at the local auto parts store and this cam was offered under performance cams but after reading around I havnt found any info to support it can be used...
Specs from Holly
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,200
Intake Duration at 050 inch Lift: 227
Exhaust Duration at 050 inch Lift: 233
Duration at 050 inch Lift: 227 int./233 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.489 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.504 in.
Valve Lift with Factory Rocker Arm Ratio: 0.489 int./0.504 exh. lift
Lobe Separation (degrees): 110
But whats Im asking is
Will this cam work in a 1999 Camaro SS LS1 car
Ive had 10 looks someone has to know.... Please help me.
Why would this cam/lifter package be listed as a LS1 cam in the Advance Auto Computer then.... God this is frustrating. Hopefully I can just go to Holly here in Bowling Green and ask them their opinion.
Guess Im off to return the cam tomarrow.
