Cam install AFTER dyno tune ?
Old 05-28-2007, 01:39 PM
soontobeLS1's Avatar
Default Cam install AFTER dyno tune ?
Have a qwik question, I already have a dyno tune on my car with exhaust bolt on's etc. If I get a cam swap done locally, can I drive it 2 hrs away to be re-tuned? My engine won't be running bad from the differernt cam will it?
And another question on the tune, the shop before downloaded an LS1 edit tune, I dont have the hardware. Can another shop with LS1 edit programming just go into my current tune and tweak it?
Thx for any info.
R
Old 05-28-2007, 06:01 PM
98redorangeta's Avatar
As long as you dont get on it the car will be safe although you will proably have to keep it alive because it will run rich and it will stall on you might also have to change plugs after you get to where it will be tuned. Any shop should be able to tune the computer aslong as the other shop didnt lock the tune.
