Turn Signal
Old 05-28-2007, 03:26 PM
ddasilva99's Avatar
Default Turn Signal
Hi Everyone,
When I turn on my right turn lights- the green "right turn" light on the dash stays solid rather than flashing. I parked the car and noticed that the rear right light is on solid (rather than flashing) and the front right light doesnt turn on.
Do I need to replace both rear and front bulbs or is there a bigger problem?
Thank you,
Derek
Old 05-28-2007, 04:11 PM
99HUGGRSS's Avatar
i think? try to replace the front right bulb. if it's not coming on, that should be the problem. is all the left turn signals working properly? is your hazards working properly?
Old 05-28-2007, 05:13 PM
vtec this's Avatar
It is your front only. I have had to replace the bulb in my car and it did the same thing. In fact I just got done doing it to my brothers camaro.
Old 05-28-2007, 05:18 PM
cookba's Avatar
how did you guys change the front turn signals. there seems to be crap in the way. do you get at it from under the car?
Old 05-29-2007, 10:22 AM
LastHawk's Avatar
Go from under the car. There is like 3 or 4 bolts to take out and pull the flap down. Still had to change it by feel but it was easy enough to do . I've heard you can go from the top too. Not sure which is easier.
I did this just a month ago for my right turn signal and took 5 minutes maybe.
This morning, low and behold, the left is out. Thank you GM for constantly reminding me the quality you demand of your vehicles...
Old 05-30-2007, 10:19 AM
tylerdj's Avatar
You're front turn signal bulb is out. If it's a TA you can open the headlights, remove the plastic cover around them and reach it through there....on a Camaro you have to go from underneath.
