Notices
WTB: LS7 block, crank, LS1 f-body gas tank, BMR K & arms..+ more
Old 05-29-2007, 12:22 AM
bowtiguy's Avatar
Default WTB: LS7 block, crank, LS1 f-body gas tank, BMR K & arms..+ more
Well I've decided to freshin up my 94 B4C Z28. rather than stroking the ol' 20K miles LT1, I've decided a warmed over dry sumped LS7 will get me back behind the drivers seat ona more regular basis. I'm not in a huge hurry on these items but the following list will get me on the way....while my other project is being finished & fab'd.
Please E-mail, reply, or PM me with the condition of what you have and how much you want for the item(s) shipped to 80516 ( north of Denver, CO.) I've been an e-bay member since 2000 user name B4C94.
-LS7 block ( or darton resleaved LS2)
-LS7 crank ( or compareable aftermarket if new)
-06-07 LS2/LS7 coil packs
-06-07 speartech wiring harness
-90mm cable operated throttle body
-Katech valve covers ( color unimportant)
-katech coil relocation brackets
-spec III or similar high end clutch assembly
-fidanza LS2/LS7 Al flywheel
-99-02 LS1 f-body plastic fuel tank assembly (everything)
-99-02 LS1 racetronics plug and play fuel system (unused)
-99-02 LS1 f-body BMR K frame
-99-02 aftermarket aluminum radiator
-99-02 F-body alternator ( must be like new)
-99-02 F-body water pump ( must be like new) -OR- an electric version
thanks in advance guys....
Old 05-31-2007, 12:30 AM
bowtiguy's Avatar
so far only a taker on the fuel system...
anyone else want to unload some parts?
Old 05-31-2007, 09:51 PM
jegan1989's Avatar
i have a 408 ls1 that will make you want to get behind the seat more check my post and let me know it is a bad bitch i have never had it in my car but it will make alot of power
Old 06-01-2007, 11:18 PM
2kredss's Avatar
i'm taking the entire fuel system off my car(2000 ss) from tank to injectors pm me if interested on anything
