drop spring install need help ASAP
Old 05-29-2007, 12:23 PM
hawaiianpunch01SS's Avatar
Default drop spring install need help ASAP
hey guys i am helping a friend install some drop springs but we ran into a snag on the front drivers side. the 2 rear bolts holding the strut in under the hood are torx heads (mine were normal bolts, his passenger side is normal bolts) anyways the problem is i cant get a torx bit in the outside rear bolt ( closest to the fender, closest to the rear of the car, under the hood) the master cylender is only clearing the top of the bolt by about half a inch not enough to get a bit in it. what do i do??? is there a way around removing the master and having to blead the brakes or is that what i have to do?
Old 05-29-2007, 12:58 PM
mitchntx's Avatar
2 nuts hold the MC onto the booster.
Remove those 2 nuts. There is enough spring and give in the brake lines to move the MC slightly out of the way and get a wrench on the upper shock assy bolts.
Then take the 2 bolts out of the passenger side and put them on the driver's side and use the Torx on the passenger side. That way, you'll never have this issue again.
Old 05-29-2007, 01:06 PM
SpdFrk1990's Avatar
I just took the MC loose and took the 2 nuts loose on the abs block and moved the whole unit out of the way thats the easiest way. Then you can get the t-50 on the bolt easy.
Old 05-29-2007, 01:24 PM
FadedSS's Avatar
just did this the past weekend. loosen those bolts on the MC and fit your bit in...
Old 05-29-2007, 01:29 PM
SpdFrk1990's Avatar
I tried to do mine that way and the hard lines to the abs block would not allow me to move it enough out of the way. Takes 2 more seconds to remove the nuts on the abs block and the whole assembly moved out of the way giving you plenty of room.
Old 05-29-2007, 02:14 PM
awsome!!! thanks for the quick help ill post pics after we are done!!
Old 05-29-2007, 10:09 PM
hey guys got the new drop springs on with your help and tips!!! thanks i dont have time to get the pics on tonght but i will try to get them on soon his car tooks awsome!!! he did the same drop as me 1.75" all around!!
Old 05-29-2007, 10:29 PM
SpdFrk1990's Avatar
Glad we could help .
Old 05-29-2007, 10:54 PM
FadedSS's Avatar
post up pics asap! glad to hear things worked out well
PierreLS1's Avatar
i wussed out and took mine to a shop
Old 05-31-2007, 05:26 AM
RedWS6 00's Avatar
I worked with a mechanic on mine. I too was a bit concerend when I got to these bolts. he said take off the master cylinder, I was expecting to loose break fluid etc... but there was nothing.
Well we took it off, moved it out the way and managed to take off the torx bolts. I have fitted the torx bolts to the passenger side so when I get to them again I shouldn't have to removed the master.
