General Maintenance & Repairs - Break Pad replacement
View Full Version : Break Pad replacement
koz28
05-29-2007, 12:29 PM
Anyone have detailed instructions on how to replace brake pads on a 1998 Z28? Like the instructions we have on here for window motor replacement is really detailed with pictures. Any chance we have same type thing for Brake Pad replacement?
Also I am considering getting Kumho Ecsta tires. Any opinions on these?
Thank you
Starion
05-29-2007, 12:55 PM
www.installuniversity.com
Check under the brake section.
slvr98camaro
05-29-2007, 07:17 PM
its REALLY easy, you take the tire off, take the two bolts holding the caliper off, take the caliper off, and put it somewhere so the hose isnt getting stretched, the pads will slide out, slide the new pads in, then get a vice and push the pistons in then put the caliper back in place, and re tighten the bolts.
